Once we moved beyond the oversized fuzz box era, we shouldāve adopted a more modular system. Pedals should just use a single TRS jack for send and return like the insert on a mixing console, and just have a bypass looper unit that they all interface with. Half as many cables needed, and then when youāre switching the order of two effects you just need to swap two cables instead of four. Would also make pedals and outboard studio gear more immediately compatible with each other.
Pretty much what I was thinking of. Brilliant in theory, just didnāt was ditched before it could really take off. Tony Levin used the Yamaha system for a while I thinkIt's different than what you describe, but I've always loved the idea behind the Yamaha PSE / Korg PME lines
Cartridge based, but not some flimsy gimmicks like the Nintendo cartridges.
If you didn't think compressor marketing was aggressive enough as it isāfolks'll be hooking up $3k comps to their 5x TS chain.Would also make pedals and outboard studio gear more immediately compatible with each other.
Clipping methods all sound the same; hard or soft diode clipping, opamp, CMOS, germanium, or siliconāonce you have a moderate amount of saturation, there's no perceptable difference. What really makes a difference is where and how the gain stages are EQ'd.
With or without magik voodoo diodes?what if theyāre in a vintage distortion +
I bought a 308 for 12 didgeridollars, and couldnt tell the difference, I sold my life pedal with an op07 cuz turns out to my dumb ears, a promethium sounds the same as a rat anyway, and takes up half the space.Lm308 vs Op07. You canāt tell the difference. Stop lying to yourself, lol.
I have to disagree. I did a fair bit of research on this topic, in the same circuit with just the clipping method being different. One aspect (and probably the most relevant IMO) is that soft clipping cleans up a lot nicer (more seamlessly) when lowering the guitar volume. Hard clipping is more suitable for really heavily distortion though, when you don't care much about how it cleans up. It is, however, possible to get heavy distortion from soft clipping too.Clipping methods all sound the same; hard or soft diode clipping, opamp, CMOS, germanium, or siliconāonce you have a moderate amount of saturation, there's no perceptable difference. What really makes a difference is where and how the gain stages are EQ'd.
That seems like a plan- If someone is tone deaf to the point that an HM-2 and a Rat sound the same, then yeah, no point in having a 308.I bought a 308 for 12 didgeridollars, and couldnt tell the difference, I sold my life pedal with an op07 cuz turns out to my dumb ears, a promethium sounds the same as a rat anyway, and takes up half the space.
now I feel obligated to build a muroidea just to sell it with the 308 in it to get it out of my collection
