zeropluszero
I guess I am that tone deaf
That came out meaner sounding than I thought in the moment. Sorry.I guess I am that tone deaf![]()
How about clean blends?Compressors should have meters
This makes me think about a tap tempo on a compressor to control the AD envelope.I'd think you'd want tap tempo before you'd want clean blend.
Chase bliss Clean’s got a side chain input.That would be a cool feature on a guitar pedal.
right now chase bliss is taking notes and adding bothThis makes me think about a tap tempo on a compressor to control the AD envelope.
But then I realized it would actually be simpler to just have a sidechain. That would be a cool feature on a guitar pedal.
It's not how it clips, it's how it transitions to clipping that defines the sound. The diode equation has a coefficient dedicated to the sharpness of a curve. Once volume is matched the difference between sounds shrinks and most diodes in use aren't different enough to justify it.I have to disagree. I did a fair bit of research on this topic, in the same circuit with just the clipping method being different. One aspect (and probably the most relevant IMO) is that soft clipping cleans up a lot nicer (more seamlessly) when lowering the guitar volume. Hard clipping is more suitable for really heavily distortion though, when you don't care much about how it cleans up. It is, however, possible to get heavy distortion from soft clipping too.
/grabs notebookI'd think you'd want tap tempo before you'd want clean blend.
You forgot the hookers and blow. Rookie move.for clout ...
A "DIY" tuner?!. The Boss tuner app is FREE! and doesn't have to be plugged into anything.
I rolled my own. Mogami 2552 + Neutrik. Had to cut down the plastic inserts Neutrik uses to keep the cable end in place inside the plug shell.I would guess because a lot of speaker jack plates are recessed, or that there is never anything so close to the back of your cab that you can’t spare the space. I still wouldn’t mind some though![]()
