Hey Doomer! Help me put a doom/stoner board together
Today I had some earth shaking sustainic activity going on at rehersals. Poison was Ge-Megalith going into Bass Big Muff with normal mode on, sustain pot almost maxed. Usually I’m using Rat-variant before Muff, but Megalith was better today. My Megalith has great noise gating propeties with ASY29 transitors used. Maybe biasing biased by my unexperience affects it? Dunno. It works for me. Sustain is there when needed and the pedal is completely silent without any hearable noise floor when guitar strings stop vibrating.
So yeah, Megalith is the way for doomy FF with different options on tonality. I have a darlington transistor on MOAR/boost circuit, but I rarely use it as it dilutes away the gritty character of what Ge transistors at Q1&2 positions give.
@Paradox916 what is this drone/feedback/sustain switch you speak of?
It was a mod I did to a Muff, based on mods from the coda effects muff page. It’s a cool way to get different textures of feedback if you aren’t playing through an amp
Here is the last one I did put the feedback/drone switch on an IRB so I can ether do momentary or stay on
And it can also have almost an slight “octave “ type feel to it while you are playing if you have it on
Getting down to it right now it’s kind a culmination of suggestions
TS > rat > muff > phaser > delay > trem
I would also add the gatekeeper to the front of your dirt chain, with the AD-9 after. Final answer.
Didn’t really dig the delay up front and fiddled with gatekeeper and the ad9 And turns out you can dial the gatekeeper to pretty much sound like the AD9 but it’s a little cleaner and I got an Oscillation switch for funnziez.
@Feral Feline
Turns out that trem suggestion is pretty fun put at the end with a hard chop and you can add a new level of crazy
To be continued…
@Feral Feline
To be continued…
Another one bi... discovers the dark si... HARD CHOP!
The better trems can go fast enough to be borderline ring-mods.
That rug really ties all those pedals together, well, almost all...
🎵One of these things...🎶
That's one of the reasons I love this board, you kept it versatile and instead of shortening cables and having to buy/make new ones if you changed things up (whether pedal choice, bigger/smaller board, etc) the neatly coiled cables, tie-downs, routing...
It's visually satisfying and also all so ...
Perfectly practical for this world AND the Off-world colonies.
ff6431181bf3daee4232bf106e0857424099bf1b.gifv
A new tone awaits you in the Off-world colonies! A chance to begin again a pedal-chain that's a golden tone-strand of opportunity and adventure!
