jessenator
Turns out if you follow the directions on the box website, crap h*ckin works.
Used a crappy, bad board of mine, fake iCs, spline shaft pots and sacrificial resistor and caps to run some tests.
Indium says that their no-clean core solder should be set to 350°C. I was skeptical.
Did a test first at my 375°C standard temp with and without additional flux. Without the paste I put down the wetting is not great, but but terrible. Paste helped.
Then I did a test at 350°C, no additional flux, and
No additional time on the heat even, I was just on my groove, only I didn't need a jagundaload of additional flux. Amazing.
The purple board (weird WB issues with my phone…) was a second test with it and it was easy peasy lemon squeezy.
Lesson learned: read the box
