mybud
- Build Rating
- 5.00 star(s)
My first Byzantium build (report here) had some issues with popping and the LED staying half lit in bypass. Since the pop makes it basically unusable for live work, I decided to rebuild it and correct the upside-down footswitch wiring mistake of the first build.
I carefully disassembled the original...
to compare the new boards with the old...
and used the first build as an assembly guide.
First order of business, to clean the gunk off the new boards...
so duly cleaned, I let them dry in the sun...
and got to work on the final assembly...
aiming to make sure that the audio board was lying as flat as possible, then soldering the pots in place...
and the two pin header assemblies, which I tack soldered in place after fixing the audio board to the enclosure with the pots.
I managed to bork a film cap on the way despite my best efforts. I also used one of Barry's ribbon cables to secure the footswitch assembly, right way up this time
to the board. Gives one some wiggle room in case of need.
Before final touches...
and the finished article. Fab-sounding flanger, but now no popping and half-lit LEDs.
Thanks for reading and wishing you all joy in your projects.
