Valhalla Distortion
thank you!
I will make the "How to vid" as soon as possible, i use Universal Audio OX for the Cab/mic simulation.
Awesome Tone again...oh cool you have the UA OX, so yea post up a How to Vid !...i was looking at those a few years back...but i now have the FM3 and a Rivera Rockcrusher that i hardly use that will do the same thing basically ...im a Tube amp and pedal guy vs modeling...even tho modeling is so fantastic these days...good to have both tho
Mike
You are correct.
How about we look at it right-side up? The VOL control is pretty straightforward. Some pedal builders install the volume or gain control "backwards." It still works, but has a different taper when used that way. The POWER output comes straight off of the VOL control. R23 & R24 reduce the signal a little and raise the output impedance for the benefit of the next pedal or amplifier preamp input. R23, R24 & C19 roll off the treble above 1.2KHz. PCBOUT and OUT1 go to the stomp switch. OUT2 goes to the OUT jack.
Hi Chuck and everyone. Just resurrecting this thread since I just built the Valhalla and have a question.
Is it possible to increase the volume in OUT2 so the Volume Pot outputs more volume, while maintaining the treble roll off above 1.2Khz?
When I crank the Volume pot it still sounds like its a bit below unity volume. However, when I plug into the POWER AMP output, there is more than enough volume.
Thanks,
Thanks,
Increase R24 to 1M-1.2M and decrease C19 to 1nF. That will give you about twice the output volume while retaining the cut-off frequency.
