Klon Woes
ac30irons
Hey all, so I have done a Klon board minus the charge pump. Used a pretty standard schematic. Just knocked one up and am getting zero sound at pin 1 of ic2, before all is fine. I have checked, checked and double checked all components etc, reflowed too - I am perplexed. Something tells me maybe I have something wrong on the schematic in loo of removing the CP and associated components, likely in the power section 🤦‍♂️
IC2 Voltages
1 - 9.25
2 - 4.9
3 - 9.3
4 - 0
5 - 9.3
6 - 9.14
7 - 9.28
8 - 9.3
Any help would be really appreciated.
Ahhhhhhhh feck, thanks dude - now to hack the pcb 😩
Worst case you can probably just bend those pins out from the socket (cuz you used sockets right?) and bodge it to VREF somewhere.
If you did SMD or soldered right to the board it'll be a little harder, but should be at least hackable without getting new PCBs made.
Thankfully I always socket ICs. Popped 3 and 5 out and bridged them. The Ic is right under the gain pot so it a short hop to Vref. Not has chance to test but will report back tomorrow.
Thanks again brother.
