Lazy Breadboard Modules [DEVELOPMENT]
rossbalch
I mentioned I was developing some lazy breadboard modules in another thread and there was some interest in the idea. I'm a pretty amateur designer so feedback and suggestions are welcome. I'll publish everything on my github so people can get involved and use the modules when they're done.
I love tinkering and designing circuits but laying out breadboards for certain things is a bit of a buzz kill for me. My idea was, what if the circuit nets were already connected in the right way and all you had to do was plug in the correct components? Because you can't cover all bases on a single PCB, I think you would still need a bread board to circuit components in between modules. As such I was thinking of designing them in such a way that they plug into a breadboard, or can just be wired in with jumper cables. I'm currently at the schematic capture stage.
All the component slots will be populated by sockets, my plan is to use these socket pins, but traditional headers will work as I'm sticking to the 2.54mm spacings.
Here are the schematics as the currently exist, in my current config certain components will need to be jumpered with bus wire, or 0ohm resistors, others can simply be omitted, depending what type of circuit you wish to build.
One thing you'll notice is no Vref, that's because I favour +/- supply when it comes to OP-Amps.
I don't think this system is beginner friendly necessarily, I would say I'm targeting people like myself, intermediate and up. You have to understand how the circuits work to know what to link and omit, but that affords the most versatility.
Here are the patterns I've "developed". They're designed to make identification easy, and allow for polarised components where needed.
One thing I think I've noticed already is the the input Caps in the OP-amp section doesn't have a path to ground.
Yeah, this really stems from my own laziness. I layed out a Rat on my own, first using DIY Layout Creator, then actually on a breadboard, and it worked first time, which was awesome, but laying out all the feedback components was a real killjoy for me. I think I'll spend a lot more time tinkering with modules like this available.
Can you share the schematic with the rest of the class @jwin615 ?
Or do we have homework-tracing to do?
I failed my most recent breadboarding attempt; I could/should maybe use some BJT modules...
Yeah, I've been meaning to fully socket a few PPCB Breadcrumbs, but have been using those multi-socket things instead — whachamacallum...
Breadboards!
Time to move back to my roots — fully socketed PCBs!
Yeah the muffin crumb inspired me to do this.
Love this idea because I hate breadboarding.
I have a folder full of other breadcrumbs somewhere... most of mine are smaller segments but I did have a few things like inverting/noninverting gain stages, voltage regulator with filter caps, various charge pump modules (inverter, doubler, tripler, etc), and a base PT2399 module.
Ok first attempt at a layout. This is the BJT module. ~60x40mm Aligned to 2.54mm spacing. There's a 5mm buffer between each component which hopefully should make exchanging components fairly easy. Trying to plug it directly into a breadboard seemed a little silly given the size, I think you would just use jumper wires to IO to other circuit snippets or between modules. Power filtering and protection etc is presumed to come from upstream, though I will probably create a dedicated module for that. I may amend this to have a single filtering / decoupling cap on each rail though, perhaps just 100nF to ground?
EDIT: Made a couple improvements
Anyone have recommendations for testing points? A reminder of the schem.
Also do my trim pot / multi turn, directions make sense?
