I'm new to pedal building, I started about three months ago and have built around 30 pedals so far. I began with some Pedal Mania boards, but almost gave up right away because my first two builds didn’t work. Then, I switched to Five Cats PCBs and had success, followed by some Moonn Electronics projects. A couple of weeks ago, I picked up about 10 PedalPCB boards and have already built three of them.
I've used this forum several times for information, so a big thanks to everyone!
Lately, I’ve also gotten into stripboard and more diy builds, which led me to discover the Funbox. Most of my builds have been overdrives, fuzzes, and distortions since modulation and spatial effects tend to be more expensive. I thought the Funbox would be a great addition to my setup, so I ordered the boards from pcbway and I gathered enough materials for three builds and completed my first one yesterday.
The build process was straightforward, and the instructions were clear, thanks a lot for that. I assembled everything, loaded the software onto the Daisy Seed, and it worked! but unfortunately, there's a very loud hissing noise throughout. I used the latest components and also tried a TL072, but no luck.
I’m not experienced enough to pinpoint the issue. The only deviation I made was using stranded tin wire instead of the recommended solid core wire, but otherwise, I used all the correct components. The hissing occurs even when the pedal is bypassed, though it gets significantly louder when engaged. I’ve tested the Earth, Mercury, and Neptune modules, and all have the same issue, so I don’t think the Daisy Seed is the problem.
I'm actually using the Funbox PCB, not the Terrarium. To be honest, I had already checked out that thread, but the noise in those examples is quite different from what I’m experiencing.
The sound I’m getting is more of a high-pitched feedback with a bit of underlying noise, kind of like a hiss, which is why I described it that way. The Terrarium examples have a more typical kind of noise.
I’ve socketed all the ICs and tried swapping in three different ones for each position, so I’ve ruled out damaged chips. The feedback is still there regardless.
I’m planning to record a video of the sound tonight or tomorrow, maybe someone will recognize it and have some insight.
-Here’s what I’ve tried so far:
-Checked and replaced the jacks
-Reflowed all the solder joints
-Swapped out each IC one by one
-Scraped paint off the inside of the enclosure for a solid ground connection
-Searched multiple forums for similar issues
It could be a bad cap, but before I go tearing the whole thing apart, I was hoping someone might have a clue about what’s going on or even @keyth72 might have experienced this himself.
Oh I forgot, I don't have TRS cables at the moment to test both changes at the same time but I've wired the jacks multiple times to check both the Right and Left channels separately and both have the same issue.
@Cwallmeier Thanks for emailing me, I wanted to respond here as well in case anyone else is getting more noise than expected. Based on the recording you sent me, you are getting much louder noise than the typical daisy seed build, although it sounds similar to the 1kHz noise (based on samplerate/blocksize of the Daisy Seed), although I noticed your sample had a peak at 500Hz.
Anyway, it sent me on an investigation of noise levels on all my Daisy Seed based pedals, and some things that may help mitigate it. Get ready for a long post with alot of graphs!
To measure noise, I used the EQ plugin in Reaper to visualize the frequency spectrum, and I plugged in each device into an isolated power supply, with the guitar volume knob turned all the way down, and the pedal output going into my audio interface. First I measured the Funbox (running the Uranus module) in active and bypassed modes. Then I did the same thing for my bkshepard 125B oled screen pedal (running a similar granular delay effect), and I also measured true bypass mode to have a baseline. Finally, I measured my Terrarium pedal running the "Seed" software. This Terrarium is the v1 board (I noticed there is an official v2 Terrarium with the lowpass filter added), but I added the lowpass filter separately to work with the Daisy Seed rev 7.
Here is the Funbox, in digital bypass mode:
As you can see, the 1kHz noise is present at around -15dB, with harmonics continuing at 2kHz and up. You can predict this noise by calculating how often the daisy seed processed a block of audio. In the Uranus effect, I'm using 48kHz samplerate with a blocksize of 48. So you do samplerate/blocksize, 48000/48 = 1000 Hz. Unfortunately it is audible while not playing, and I think it's safe to say this is an expected baseline for the Funbox circuit. It's a through hole digital board, and the components are tightly packed. Not ideal, but I think that's the reality of the circuit I designed.
Next, here is the Funbox with the Uranus effect active (but no sound coming from the guitar, so this is only noise from the Funbox):
The noise profile is similar, but the peaks go above -12dB. Ouch!
Before moving to the other pedal hardware, I'll show some ways I was able to reduce the noise, but there is a trade off.
By changing the block size and/or samplerate, you can push the noise out of the audible spectrum (above 20kHz). First, I tried reducing the block size to 4. This changes the noise equation to 48000/4 = 12000Hz. Still audible, but interesting to see the result:
This is much better! But that 12kHz spike is still too loud. Also, as Uranus is currently written, the Daisy Seed was not able to keep up with processing, there were audio dropouts (clicks).
Next, I reduced the blocksize to 2, knowing that the Daisy Seed wouldn't be able to run the effect smoothly. 48000/2 = 24000Hz, and as you can see from the graph, the noise spike is not present.
There's another part to the equation, which is the samplerate. Unfortunately with the current libdaisy (unless I'm mistaken), the only samplerate above 48kHz available is 96kHz, which also makes the effect more difficult to process for the Daisy Seed (double the samples to process in the same amount of time). So this time I tried 96kHz samplerate with a blocksize of 4, so 96000/4 = 24000 (same as previous). The resulting noise profile was pretty much the same:
And as before, the Daisy Seed was not able to keep up without audio dropouts. However, it wasn't terrible, so I think if the Uranus code was reduced to use less granular particles, it would be able to run smoothly at either the 96kHz/4 blocksize, or the 48kHz/2 blocksize. Some of the other modules may have similar performance, but others (like the neural net based ones) would be impossible to run at those rates.
To summarize, the Funbox is a bit noisier than I realized. I think the component quality plays a factor. I'll also take more care when writing the algorithms to push any noise spikes out of the range of hearing, and maybe look back at planet modules to see if I can improve the noise profiles. If you get louder noise than what I'm showing above, there may be other issues with the build.
Now to compare with other pedals, first I'll show the 125B oled pedal. This one is a SMD board, 4 layer. I think the SMD components play a factor in noise reduction, and possibly the additional layers provide shielding. Any EE's out there feel free to comment!
Here is the 125b with the granular effect on, running at 48kHz with a blocksize of 48:
This is MUCH better. No noise spikes and very quiet background noise (digital bypass looked almost exactly the same). To compare, here is the same pedal in true bypass mode (the pedal is completely bypassed, direct connection to the guitar):
So the pedal adds some noise of course, but to my ears, a negligible amount.
Next, I'll show the Terrarium with the Seed software running:
You can see the noise spikes around 1kHz, 2kHz, and 3kHz, although the overall noise is less than the Funbox. Even though the Funbox uses a very similar circuit for the input/output/power, there are many more components in about the same amount of space, so I'm guessing that's part of the reason.
In summary, from my limited testing, the bkshep 125B oled pedal was the quietest, followed by the Terrarium, and Funbox was the noisiest. You can increase the samplerate or reduce the blocksize to help reduce Daisy Seed noise, but at the cost of processing power. With a well designed circuit (and possibly SMD as a requirement), you can have a Daisy Seed based pedal with almost no noise, as with the 125B oled pedal.
Yes, Pluto would actually be a really good one to try it on, because it's already running at 96kHz, and it's not doing super heavy processing for the effect. Try lowering the blocksize to 4.
It mentions using "Recommended Circuits" for op amps, part choices, etc, but I wasn't able to find that in their datasheet. I'm asking around to see if that information is available yet, will post back here if I find it.
^ This is typical of the deflection and irresponsibility I have come to expect from Electrosmith. I have a few unused Seed boards if anyone wants them.
Yeah, I didn't get an answer from Electrosmith but someone on the Discord said there weren't guitar pedal related recommendations available. The legacy Petal schematic is still on their website, and may be the closest thing to give us any hints. In any case, the bkshep DaisySeedProject pedals are based on the Petal schematics, and besides the addition of the lowpass filter on the audio out, I think it mostly matches it, and that pedal works well and is quiet.
The patch submodule looks interesting! Besides the form factor, I'm curious about differences from the Daisy Seed, looks like it has built in CV inputs?
Update: Someone from Electrosmith did respond back, that info is TBD, and is supposed to go in the Daisy Seed Datasheet pdf when they update it.
Yes. It uses bi polar power, the whole circuit has better manners than the seed. I don't think it is a reasonable choice for pedal fx but you could make it work. The audio is something like 6vpp nominally which should be considered.
@temol Yes, if they have a function on the particular planet module it should be shown in the infographic image and the readme associated with that module, but many of them are currently unused. They can be programmed to do anything that requires a switch with two positions, mainly on/off, enable/disable something. They are simply 4 switches connected to 4 of the many GPIO pins on the daisy seed.
Wanted to share this video about building the Funbox, made by a Youtuber called Naaackers, does alot of tech and DIY videos. He does a really good job of explaining the project, and even has his own build guide based on his experience (link is in video description). He has a detailed parts list and links for buying individual components, great for anyone not super familiar with building guitar pedals.
JLCPCB has Black Friday (week) sales - so I did my first PCB order ever! On Monday I got $20 off and got 20 each of the version 2 and version 3 boards for $15.96 shipped. (They are on the way now, though I picked the cheapest shipping so it could be a while.) not sure if the v2 was ever validated but I will report back once I order parts and get around to testing it. (And I might have a few spare boards if anyone needs one or two.)
Has anyone located some interesting pedal deals this time around they'd like to share?
I have just seen that there are quite a few nice deals to be had on Thomann in the "Misc guitar effect category", especially on Pigtronix and Foxgear stuff. Philosopher stone etc more than half off...
Buy Miscellaneous Guitar Effects + accessories online from Europe's largest music retailer ✔ Fast shipping ✔ 30 days money-back ✔ 3-year Thomann warranty
www.thomann.de
Edit: shit is flying off the shelves, two pedals already out of stock as I type this.
Oh, and congrats on your first PCB order. I wish I'd been more on the ball and been ready for this sale.
