It’s for the Demeter Compulator. Where are you seeing them for $5 ??? I literally can’t find any ‘genuine’ ones anywhere.I think xvive still makes them. I'm seeing them as low as $5 but shipping might be a bear. What circuit is it for? that might help determine if a roll-your-own part is a viable option.
So these are all over the eBay and Ali but the xvive ones don’t look like that at all ! Have you ever tested them ???
I've bought from both of these vendors with no problems at all. With shipping (to the US), they are 2.60 each.
I received ones that worked just fine from Huayi and I order other stuff regularly from Adele. I don't know if those are stock photos or what. These two are obviously well vetted vendors with strong positive feedback on this item. I've never gotten a part that didn't work, ever, from any vendor, in 30 over years of doing this.So these are all over the eBay and Ali but the xvive ones don’t look like that at all ! Have you ever tested them ???
light resistance is anywhere from 200 - 400 ohm
Is that a hint of sarcasm Mr Robert …. Or …. Do you believe in your expert knowledge its ok ?Reaaaaaally.......![]()
Ordering a few of those to play around with right now.
And that’s my dilemma, is it ok ??? They fly up quick to the MegsIsn't that more or less in the Xvive specs? https://eadn-wc04-3257698.nxedge.io...ads/sites/2/2021/11/Xvive-5C10-Data-Sheet.pdf
I guess the Off resistance is much more than 400k resistance it says, but I don't think 400k or 20M makes much difference in our common use?
I grabbed them from Huayi, they came from china to uk pretty quick also. How do you you feel they would do in the Compulator with the off resistance being so high ?No, no, no sarcasm (and I'm far from an expert).... I just need some vactrols with low light resistance.
