Hello everyone. I just finished a kliche overdrive, the problem is all it does is hum when it's on. The volume pot makes it hum louder and quieter but no actual guitar signal seems to be getting through.
The last thing I tried before this picture was switching the lugs connecting to the in on the PCB and the negative battery connector. I can't remember if the pedal was even humming before I did that so I don't know if it changed anything with the signal, but now the pedal doesn't turn on from battery power, it requires the wall plug to turn on.
I can remove everything from the enclosure for more pictures if needed but for now I'm hoping that someone with more experience will see the wiring or the symptoms and have an idea of the problem.
I will also take troubleshooting advice anyone has. I have just been doing continuity tests on things that make sense but that's basically my troubleshooting experience.
Thanks for the help
Thanks for the help
