Trademark / Fuzz Bender
Erik S
5.00 star(s)
This is a cool circuit!
I watched the Keeley video to try and wrap my head around what was going on with the controls - I think he said it's based on a tonebender, but with an active 20db boost/ cut eq similar to a metal zone. He also said he's using a Japanese germanium transistor around 100 HFE and whatever it is is very consistent across each unit.
A few folks had reported that selecting the right Germ was important, so I made the bold/ shameful decision to install a socket. I hadn't used one of these To-5 sockets before, but I have a pile of them from an estate lot and they're much nicer than the snap-off inline sockets I've used before and had problems with. These grip a lot tighter and are hollow all the way down the pin so they accept a longer section of leg. Hopefully it doesn't come back to bite me later.
@Mentaltossflycoon said their audition winner was an MP38a over 100hfe, so I had pre-selected one of those with pretty low leakage, but I didn't end up liking it and was glad for the socket. After that I just grabbed everything NPN and started plugging in random stuff. My favorite ended up being a cool looking Sylvania 2N214 that probably came from the same TV repair-guy estate. 70hfe and a little higher leakage, but I liked that it had a little more range of clean up with the volume knob than some other candidates.
Two weird things about this layout - Dual gang in the middle of the board is a little bit of a bummer for insulation purposes (made worse by my socket with it's long untrimmed tube-legs) And the LED location on the paper template is at the top, but the LED pads are at the bottom, so I had to run some wire. But overall still a pretty nice layout. Plus @Robert was thoughtful enough to stock both the 6428 transistors and the dual gang pot in the store which is nice.
I've had a hard time connecting with the handful of old school style fuzzes I've tried, but this one might stick around for a while.
And check out that pink LED! First time I've used one of those, and pretty excited about it.
That matte enclosure looks like it belongs on “Is it Cake?”
If you would have used white cupcake knobs it would have looked downright appetizing.
How are you applying your text?
Cupcakes would have been a good choice!
I've been spraying everything with a matte clearcoat, so all the colors end up with that fondant icing vibe.
Text is via a weird rig based on some 1950s drafting tech.
You got me sifting my stash again. I found one that's 72 hfe and .12 mA leakage that is the new favorite though the cleanup suffers some. I found another at 50 hfe .23 mA that cleans up nicely but only sounds decent with the bias dimed. The first one I prefer with bass, the second with guitar.
So after much ado, I've landed on liking something about several transistors but no clear winner. 😑 Maybe if I buy a few more boxes of ebay germs I'll find the money tranny, right? Right??
That's what has put me off of messing much with tonebenders and the like up till now. I did order a batch of Germs from the Ukraine a while back and added some more fuzzes to my backlog, but it sure is a lot more trouble than the stuff where you just put the right parts in the right holes and the pedal sounds right.
I wonder how different my build ended up being to a Keeley one with the germ I picked. I was definitely prioritizing the lower gain side. With the bias and fuzz knobs around 9 o clock and my guitar on 6 I'm getting a nice dynamic medium gain thing happening. Definitely not a sound I heard in the couple demos I watched and probably not really the intended use case for this. :ROFLMAO: I'm also not getting the splatty gated thing on the other extreme, but I care less about that.
I've done some other pedals where the bias knob felt like it should have been a trimmer- set it and forget it, but this one feels like a second more powerful gain knob. Between that and the EQ I think this has a really nice control set if you can find the right transistor for a base sound you like.
I guess I should try it with bass...
Came for the lettering, stayed for the skateboarding. 🫣
[X]
Since this is a public part of the forum, I will remove this image after I made you remember this. 😅
Enjoyed the keystep jam as well. Moody!
But your off-board wiring stays oh-so fine...
I also built this and I'll have to go check, but I think mine was a good ole 2n169 that won the covered germanium slot.
I do like the pedal quite a bit, especially with the bass control cranked. Pretty excellent low and slow tones
