I'm still wonderin' about that 47r5 resistor! Why that exact value?
I also love that 8-Bit control, and I'm not sure why it hasn't been incorporated into any other fuzz designs... maybe it has..? @bean may have the answers!
Thanks Brian. I know at minimum resistance on the 8bit control is where the misbias happens the most, so can't really make the pot bigger to achieve more. I guess I will fiddle with the collector resistor a bit and see if there is some wiggle room there. That's funny about r5. I read it as a 47.5ohm too and was like no way I'm ordering a special resistor for that, lol. I was really pleasantly surprised with this build and will probably try for another filter capacitor to use with on/off/on toggle and narrow down the clipping options to do an on/off/on with resistors to even out the volume when changing.
I really need to add that Filter to a Fig Buster at some point - always felt like I was missing out! That parked wah idea sounds pretty cool...My one contribution was adding the two filter caps in the feedback path of the first two transistors.
Ah so it is kinda like the Mammoth's Pinch control - the difference being that a FF usually has this control between Q1's base and Q2's emitter, whereas the Clusterfuzz has it between Q1's collector and Q2's base.The 8-bit controller reduces current flow to the base of the 2n5089 so it ends up being a crude bias control (but in a good way). It's a similar effect to adding additional resistance in the feedback path of a traditional Fuzz Face.
Check Szukalski's Gerbers for the Sheepylove Figbuster. For the Clusterfuzz, I'm not sure it was ever offered DIY. Something close, maybe Moonn?Is there a pcb for this project somewhere?
I'm pretty sure gerbers work on a phone too - they're basically the files you send to a PCB fabricator (a lot of people here use JLCPCB but there are others) so they print the PCB. That means you can download the gerbers, upload them to JLCPCB, and get your very own set of PCB's printed like that.@Feral Feline I don’t really know what Gerbers are, no computer, but I gonna thank you anyways my friend. Starting to think I finally may be missing out by not having a computer lol.
Is there an app needed to read or open Gerber files?I'm pretty sure gerbers work on a phone too - they're basically the files you send to a PCB fabricator (a lot of people here use JLCPCB but there are others) so they print the PCB. That means you can download the gerbers, upload them to JLCPCB, and get your very own set of PCB's printed like that.
You get to pick the color too, and it's pretty cheap for a first time user at least, and even afterwards if you order multiple ones at a time to save on shipping. The downside is that it's usually 3 or 5 minimum, so you end up with extras, but if you have friends who also build pedals it might not be a bad thing.
I assume so - if you have a machine that can print PCB's.Is there an app needed to read or open Gerber files?
