Robert
George Cloney
What an emotional rollercoaster
Look, I'm just glad he didn't immediately jump to blaming the PCB.....
I messed with it for a few more hours and replaced more items. It is like guessing and hoping and that is just a recipe for a burned out board. Put it back on the auditorium and got nothing - messed with it some more. Now it is on the scrap heap. I always order at least two boards in case of mistakes. It is frustrating not having the knowledge I need to trace. Anyway, carry on, I will build another because I have another board. Thanks all.If it works out of the enclosure but doesn't work when you put it back in the enclosure something is making contact with something it shouldn't.
The most likely cause is a component lead touching the back of one of the pots.
When it's out of the enclosure the pots aren't grounded and are floating, so it doesn't cause any issues... once you mount it back in the enclosure (which is grounded by the 1/4" jacks) the metal pot housing also becomes ground and shorts whatever is making contact to ground.
We could be if we were doing PCBmania pcb clones over here..lolLook, I'm just glad he didn't immediately jump to blaming the PCB.....![]()
measuring components while in circuit doesn't work out exact...... other things it's connected to affect itWell, I put the new one up on the auditorium and it works. One question I have is how come the A1 M only registers about 350k. Out of the board it registers 1M. I noticed this with the last board as well. I’m wondering if there’s another resistor that is throttling the A1M down to the 300s.
All the other variable resistors reached their peak of 25K 10 K and 100 K. I’m sure it must be something in the design because it works. Now we gotta cross our fingers while I box it up. I also changed the design from that two lines and a rolled up 100. Classic eight ball design now.
Thanks! I wondered.measuring components while in circuit doesn't work out exact...... other things it's connected to affect it
