I have a Dead End FX Inchdown Redux to build and it calls for ferrite beads but specifies no values. There are 2 of them in the power section of the pedal. Any clues as to what to buy?
Thanks
Pretty much any are going to work in that build - the cheap Tayda ones will be fine (it's just to reduce HF noise into the regulator - it's already got a lot of noise rejection so values aren't critical).
Thanks to everyone. This is the first time I've ever seen them specified in a pedal. I did a little research and there is an equation to compute a value if you know what frequency you want to filter.
