3-D Printed Discs For Transistor Sockets?
Ginsly
Probably more trouble than it's worth, but... Anybody ever 3-D print the plastic part of these sockets?
They're more expensive than the transistor in many cases! Seems like you could just pop the metal sockets out of one of those SIP rows and place them in a printed disc...
Let me get this out of the way to save us some time! "Or you could, ya know... just not use sockets at all... Just sayin." Perfect! Yes, that's luckily an option :).
That does sound like a pretty useful idea, if one has a 3D printer.
Personally I just solder in three small metal sockets (or just singular SIP sockets with the plastic on), held on by blu tack while I solder them.
Yep, that’s what I do too. The little disc provides some stability though. It’s wild how expensive they are! I don’t get it.
Luckily access to 3D printers has expanded- as long as you have a design & files you can even go to the library in some cases. Something like this would be incredibly quick to print, too.
Laser cutting them would be much, much simpler - I've made a few subminiature tube sockets with machined Teflon and header pins, but laser is cheap and easy.
I’d like to hear more about this, didn’t even consider it… what material would be used?
