thunderaxe
over spec by how much? and how stable would that make them?You've heard or even used plenty of circuits with X7R caps in the signal path. One way to minimise the "downsides" is to over spec the voltage of X7Rs and Electros.
Your SMD footprint doesn't have to 100% line up with the one on EasyEDA, the part just has to fit, oversizing so you have a hand-soldering option isn't a problem. I usually make my own footprints for things, but Mouser and DigiKey have an ever-growing number of footprints for every software out there, and they even offer 3D models. I've never used KiCAD so I don't know what the process for loading a footprint in from a file looks like, but their footprints are pretty reliable.i've got another question: how can i be certain i have the right footprint for the PCBA part? i wish that was a feature of the bouni JLCPCB plugin.
for instance, for a reverse-polarity protection diode, there are no 1n5817s available in basic, but there is this 1n5819 which as far as i can tell is essentially the same thing:
1N5819WS | Guangdong Hottech | Schottky Diodes | JLCPCB
1N5819WS from Guangdong Hottech - Schottky Diodes is available for JLCPCB assembly, check the stock, pricing and datasheet, and let JLCPCB helps you assemble the part 1N5819WS for free.jlcpcb.com
okay, so it's a SOD-323 package, and i take a glance at the easyEDA footprint. should be enough to go on, right? except that there are three different SOD-323 footprints in KiCad, and none of them look like the easyEDA one. the hand-soldered one looks close, but it's not quite right either. worse still, the recommended footprint on the datasheet is different from both the easyEDA footprint and any of the ones in KiCad. i ended up creating my own, but i don't want to have to do that too much. i just want to be certain that i have the right one to make sure the assembly is done correctly.
would this apply to any manufacturer's capacitor of the same specs and package? or just murata's?Murata has an online tool called 'SimSurfing' where you can look up the exact capacitance derating curve for any of their caps.
My guess is that the curves won't be exact from manufacturer to manufacturer -- but Murata's numbers will probably be a reasonablewould this apply to any manufacturer's capacitor of the same specs and package? or just murata's?
