Skreddy Animals Major OD/HamishR Old Fashioned/Prey Drive PTP
comradehoser
5.00 star(s)
Upon @HamishR 's enthusiastic suggestion (thanks, bud!), I had a go at this circuit. The breadboarding was super dumb, but I struggled through it, loved the Marshall Big Rock sound it gave, and of course I had to try to PTP the thing.
This time, though, I had a concept and did graphics and drilling as you should before assembling PTP. I drew upon my dog Marx's manic moments (he was a red nose pit bullterrier, RIP at 17). The paint was supposed to be red splatter, turned more pink frosting. I edited the drawing as well to make it more aggro as the original looked kinda derpy.
The assembly was painstaking but normal for PTP. 9v line on the left, ground on the right. Base layers first, and I did tie ins and components for all pots (except I forgot to tie volume 1 to ground, d'oh. Didn't discover that until I plugged in).
Started at the ins of the circuit and just moved through it. The 9v line ended up being a bit odd, but I wanted to respect what the circuit sees in order.
Most of the circuit was situated through trial and error, constructed out of box around the transistor arrays, and then connected and installed. I had to employ verticality to relate everything correctly. Waaaaaay easier than breadboarding. My daughter said it looked well organized. I guess that means it's OK. Not quite as aesthetic as my last build, the OK Doomer, but I'm pretty happy with it.
Dynamic, amp-like tones, can get beautiful decay with the right transistors and biasing. It never really gets clean, can get tite and chuggy with a bass cut, but generally stays more in the land of warm middy overdrive than the animals/diamond peak which is a bit more angular and easily able to fuzz out. Like I said before, gain at 10 bass/treble noonish you can cop the back in black tone almost exactly. You can also find some Rocket from the Crypt/ Drive like Jehu/Hot Snakes in there too. Very satisfying and fun to play.
original take
modified
with knobs and LED concept
Aaaaaa the light... transistors! (That wasn't on purpose). Used low-gain silicon transistors from a stash so very kindly provided by enabler supreme @jwin615. 48 hfe at Q2 (MPS 2369 the lower one) and a 63 hfe (Motorola? 2N5330 the higher one) at Q3. I don't know if the ascending hfe order matters so much or at all as in JFET circuits, but I thought it couldn't hurt and it didn't. I tried a bunch of combos, I even installed 20-something hfe metal can transistors backwards by accident (collector-base-emitter reversed). I had a hard time getting the circuit to sound bad even with my mess ups, but this combo sounded best and probably closest to original intent. I contemplated putting the backwards transistors on a switch because I like the openness and clarity they gave, but then I remembered this is a PTP in a 125b with 4 tie ins, so I would be rolling the dice on space and complexity. So, no.
Here's what I wrote elsewhere: "I noticed were some trends: higher gain transistors as well as higher bias works, but it makes the circuit less organic/amp-like and more synthetic/ effect-like. (Also, one of my transistors at higher gain was creating amp-like feedback). The 4.35 [ he later settled on 4.6, actually] bias for Q3 collector Chuck identified is a great baseline.
To me, I like a lower Q2 because it gives a nice organic (maybe uneven or asymmetric?) quality to the distortion decay which sounds good to me, and doesn't lead to sudden crackly cut off to the clipping with gain at max."
I might mess with the bias a bit since I probably bumped it on installation--there are some artifacts I don't like as much with treble up and gain down. The bias does affect the nature of the decay of the breakup and I really like a gradual decay. Too subtle and precious an adjustment? What can I say? I like what I like.
Here it is with its big bro/sis the Diamond Peak/Animals
Still looks like amateur town with wobbly and unstraight lines. @ErikS better do a PTP soon so's people can see proper nice lines.
A look at the verticality
And another view
So cool!!
And so glad you like it. Skreddy deserves much more recognition. He's a genius.
As for blood spatter... I have only ever once used Tayda's UV print service and have been very impressed with it. One thing I tried was to use a texture black finish and the use red type outlined in white (ie a white base layer with the red overlaid) and use a gloss varnish only over the type. It works really well. So you have the regular textured finish and the gloss lettering seems to vividly float over the black texture. I imagine that if you created a blood texture pattern you could apply that in the white/red/gloss varnish sequence in that pattern and it would look fairly convincing.
But I like what you have done. You must have a lot more patience than I do.
sick build man 🤟🏻
might have to breadboard this one soon.
I don't know if it will meet the standards of owlexifry tite chugginess! You can definitely get higher-gain marshall tones and pull out some squealies, but it's less dry than say a Revv3. Maybe boosted? Haven't tried yet. In any case, it's a pretty low parts pedal and not particularly hard to breadboard (if you remember how to breadboard and not have to rediscover everything every time like a dummy).
For you, my friend, and anyone else, I would really, really, REALLY recommend the @Chuck D. Bones mod Okko Diablo. Chuck's mods always improve pedals, but these mods really make it into something way better and more interesting. HUGE range, AWESOME sound, SO versatile with the mods and attentiveness to the JFET stacking. Probably the best and most interesting dirt pedal I ever built, even from the controls perspective. From sparkly jangle to crushing fuzz, loose big rawk to (drum roll...) super tite chonky chugs.
I love the Skreddy stuff for simplicity and design, but if there could be only one, the Boneyard Diablo would get the nod for me.
For the life of me, I don't know why Chuck D. isn't collaborating with someone to make legendary pedals. Some pedal-bible level stuff going on sometimes... like I can't even believe I made such a good sounding circuit happen.
What are the noticeable differences in the two Skreddy designs to you? Do you have a favorite?
Where can one find the Boneyard Diablo? Or can the ppcb board be modified? Actually, I don’t understand why @Robert doesn’t offer the Boneyard pcbs other than the couple that he does carry. I’m sure he and @Chuck D. Bones could work something out. It’s a pain trying to source these boards in the US!
Yes, actually, they are very distinct. The Diamond Peak is much more transparent and open/raw sounding than the Major. It can also get into fuzz with bass control and gain dimed. It has a wider range of tone and gain.
The Major is very Marshally--amp-like, pushed mids, compression, big rawk sounds.
Both are articulate and very responsive to picking dynamics, though.
As for my favorite--- all my children are my favorites hahaha
On the Okko Diablo: modified. Here: https://forum.pedalpcb.com/threads/this-week-on-the-breadboard-okko-diablo-v3.25144/
I think one of the reasons on the paucity of boards may be that a lot of Chuck's JFET mods require measurement and selection. Certainly, the Diablo does. I mean, I built it stock the first time without attention to specs, and it was great, but the mods with ascending J201 values is *chef's kiss*.
JFETs do take sone time to grasp. I need to spend more time learning about them because it’s become apparent that proper selection is what separates a decent aiab or distortion from a great aiab or distortion.
I should have mentioned, the characteristics of the pedal will also change with biasing. I like the biasing 10K trimpot sub for the 5.1k resistor feeding in from the power line to the collector of Q3. It really allows you to define the characteristics of the breakup and decay. Could be a candidate for moving to a pot on the outside of the enclosure, but I have a strong preference for one bias setting/avoidance for others.
For the Major: warm middy big rawk with smooth breakup and decay. For the Diamond Peak: a little more gain/louder, more "headroom-ey", less compressed, more hi-fi sounding (more open treble and bass EQ), with as smooth a breakup and decay as it will allow. It can pan open and louder with kind of a more sporadic break up, or more closed with a more even and almost fizzy breakup
Any time you build a JFET circuit without selecting JFETs and/or checking the bias, you are rolling the dice. My mods are not more sensitive to JFET selection. It is I who is sensitive to JFET selection.
