thunderaxe
i'm guessing there isn't an equivalent of a CD40106 with less inverters in it in a smaller package? say, a 3x in a DIP-8 or even a dual in a DIP-6?
Nope. But they can be purchased in an SMD package. So can a 555.i'm guessing there isn't an equivalent of a CD40106 with less inverters in it in a smaller package? say, a 3x in a DIP-8 or even a dual in a DIP-6?
is this not true bypass with a CD4053?Analog switches require more parts than a relay solution because they do not support true bypass.
i remember reading about that on electric druid's page about designing a tubescreamer-style overdrive pedal, but re-reading it now all it really says is that the FET switches need isolating from the outside world. doesn't go into details.In theory, yes. And it might work in some cases. Do you ever wonder why Boss & Ibanez put buffers before and after their FET switches?
should i have any series resistor for the relay power, or just skip it entirely? and are 100u+100n the right filtering caps for the relay?R101 is too large for the amount of relay current you'll have. I recommend providing a separate filtered power rail for the relay so that changes in relay coil current don't bounce the pedal's Vcc.
