HellGuapo51
Hi all. I have built 6 Nobelium pre amps so far, I love the way they sound, and they are a very solid build. The only issue I have been running into is the threads on the power jack strip and make the connector loose. This has happened on at least 3 builds. I tried not tightening them as much, but then they are too loose to stay on. I feel like it has something to do with the plastic threads that also do not wrap all the way around the jack, they are flat on the top and bottom. I have tried searching for other more robust threaded jacks, but all the positive ring jacks I have found look very similar. Is there a trick I'm not doing? Or have I not searched enough for alternatives? This has also happened on a couple of the volume pots, I noticed they are made out or a pretty soft metal. Thanks so much for you help! I appreciate it! I have been lurking here while I make my builds, this is the first time I couldn't find an answer by searching.
