Rpschultz13
Hi,
I have a circuit I've been working on. Newest iteration has switch pop that I didn't have before - this is usually considered DC offset across the switch hitting the audio path. I've simplified the circuit to just the below, a JFET and buffer. The switch is simply wired as a test case, to pass signal or mute. I've tried different values of R11. Initially had nothing, then 1M, lastly 10k. The 10k worked for a few seconds but eventually the charge built up and wouldn't go away.
In a previous iteration, JK1 went directly to the switch, and then the JFET, buffer and rest of circuit. But to cut down on noise pickup I wanted the JFET as close to the jack as possible so I rearranged the routing as such. I'm not sure if that's related to the switch pop or not. But the previous version doesn't have switch pop.
Any ideas?
Any ideas?
