I’ve seen some people connect their breakout boards this way but this is my first. Didn’t have any solid 22 but I had some pre-bond and I stripped it. This is an ADHD. I hope this is the way it should be done. It certainly feels right.
I have been working with film free decals and 2k clear coat and In have only completed a few pedals in the past weeks. The preparation of multiple cases is because each can of SprayMax 2k is 30+ dollars with a shelf life of 1-2 days. I wanted to use up as much of the two cans I because of that. This stuff is a two part hard automotive clear coat which is impervious to most chemicals.
Not all of these are film free; the singled out individually pictured builds I think were mostly normal waterslide. The Analogman gold case is one with the film free and clear coat. The prepared cases on the table are about half film free.
The film free is excellent and the two part clear makes this much more professional IMO. I usually drill all the holes first and then do film free - I followed some ideas from tutorials found in this forum and then I employed my kinetic-trial-and-error -learning style - I know others may do it other ways and YMMY.
After it dries it is rock hard like the clear coat on your car; itt is a two part automotive clear. The satin/matte version is easy because you do not sand it and it looks terrific and flat. The gloss requires me to work a bit- I wet sand with 1200 and then buff with 4 different compounds. You could just spray gloss clear and leave it, but the extra sanding, buffing effort is worth it IMO.How's the smoothness of this clearcoat? Never much of a fan of glossy because of the cellulitis this mostly results in... I only dare use it with hammer effect paint.
Final Phase??FWIW, to keep e-cap profiles low, I often use SMD e-caps where I can. I find that on most builds I can use 10µF ( and higher) SMD caps.
(The e-cap in the upper right is a 33µF, which I didn't have in SMD. But it's still low enough for this build.)
I don’t wanna say it’s the “right” way but that kind of appears to be how I do it. I solder about 3” of buss wire to the board then slip the daughter board on, slide it down the leads until I find the right distance and then fold it all into place on the switch and solder. I would’ve never thought to do it that way until I asked @MichaelW how he did it.I’ve seen some people connect their breakout boards this way but this is my first. Didn’t have any solid 22 but I had some pre-bond and I stripped it. This is an ADHD. I hope this is the way it should be done. It certainly feels right.
Pretty much, yes. It's a Countdown Phaser from LectricFX; a ten-step (pole) phasing circuit.Final Phase??
Very nice.. adding to the future backlogPretty much, yes. It's a Countdown Phaser from LectricFX; a ten-step (pole) phasing circuit.
(planned finish . . . .)
Kinda looks like….Rocktron Black Cat Moan baby lol! Actually a pretty good wah.I apparently like to hurt myself. This is a custom ShamWah I made for my rhythm guitarist that he requested I put in a treadle reversal switch, so heel/toe becomes toe/heel.
