There isn’t a posted build doc on them so unfortunately at this time you will have to create one using the actual board. When there is a build doc I can create one.
I actually figured out a drilling template for the Lycan, and it worked great. I got the placement of the SPDT switches from the Xotic SL Drive template and the potentiometer placement from the EQD Westwood drill template. I had to color outside the lines a little bit, but I got everything to line up properly.
Yeah, I was going to suggest digging around and looking at Robert’s other boards for ideas. He uses standards for most things so it’s likely portions appeared somewhere else on another board. I am happy you figured one out.
