SOLVED Modify Linear Pot to Log
jkjkjk
Hi there,
I just finished up the Special Overdrive. It calls for a B100k volume potentiometer, but I'm finding that it uses up a whole bunch of volume in the first quarter turn. Seems like the solution is to switch to an A100k, but I don't have one on hand. I've read that I can solder a resistor between the middle and ground lug of the pot to make it more like a logarithmic pot. Can anyone advise on this - do I just add it to where the pot legs poke through the PCB? And which ones would be middle and ground? And what resistor would I add?
Thank you!
Because adding a resistor in parallel to any two lugs of a pot results in a lower combined resistance, one needs to start with a higher value pot to achieve a taper change while retaining the same relative pot value. So if you want a about a 100K analog taper pot, you need to start with something about double that value. The rest is parallel resistance math.
This chart should help you get started. It assumes the pot having its taper adjusted has a linear taper.
Thanks for sharing this. If I use the existing 100k pot, and I put a 10k resistor, does that just mean I'm limiting the max sweep? Like if I'm not hitting "10" on my volume pot right now, would that be ok?
No, you're also changing the loading of that gain stage. That can have undesirable frequency response ramifications on top of whatever gain changes that loading change may bring. So as usual, it depends. ;)
Besides what @Passinwind states, when you do the math, a 10K resistor in parallel with a 100K pot will result in a <10K pot with the applied taper. If you add a 100K resistor, the result would be a ~50K pot with the applied taper. I imagine you really want a 100K pot with an analog taper, so I'd start with a 250K pot and apply a 160 reistor to get ~97K audio/analog taper pot.
A good rule of thumb is if you have any volume control with a Linear taper, you'll want to swap it to a Logarithmic taper for a better sweep.
Now I've learned, will definitely keep this in mind for future builds to have a spare logarithmic taper.
Try a C100K while you’re at it
Unfortunately I don't have one of those available! Trying to figure out how to get a single potentiometer without it being dwarfed by shipping costs. Which may just mean ordering another batch of parts, haha.
Ok, one more question here to pull on the wisdom of the group. Still toying around with the adding a parallel resistor idea: I have a 220k resistor available. If I add that to the pot in parallel, then the math suggests this would result in about a 67k audio taper pot. Is that ok to try to see if that’s enough headroom? I also have 100k and 150k resistors lying around.
Sure. Doubtful it would hurt anything to try. If you're confident with your de-soldering-foo, go for it.
I’m not sure about the rest of the group but I find once these pots are soldered it can be REALLY difficult to desolder it all the way without damaging something. You be better off just dealing with the linear pot or getting a new board. My soldering skills suck though so I maybe wrong.
Ok, so I tried various resistors in parallel - 47k, 72k (33 + 39), 100k, 150k. They do move the resistance sweep, kind of maybe 35% instead of a true 15% of an audio taper. None of the combos quite got me to where I wanted it. 100k and 150k felt almost the same. 72k was ok. 47k was closer, but then I think the tone suffered, and I would have random drop offs in volume, so it was probably messing with something overall.
I took the parallel resistor off for now, just dealing with the extremely sensitive sweep of the volume knob with the gain up anywhere above 3.
For any future readers: if you are building the Special Overdrive (Dumbloid Clone), use an A100k instead of B100k for the volume pot.
As for desoldering a pot - I’ve never done it before but have removed other parts with a wick. Is it harder because it has three connection points?
I remove pots using a hot air station it works best IMO. You can do a few different things to remove them. If I didn’t have a hot air gun i would call it an 40-80 cent loss cut the legs and remove the legs individually and solder in the new pot. You can try the wick, its never done great for me. One of the vampire sucker tools will do it, ok. Again never worked great for me. Solder in a piece of wire between the three pots to conduct the heat, again never worked great for me. Theres shovel tips I’ve never tried.
In short if you don’t have a hot air gun, just cut it out and remove each leg individually its way better than spending 1/2 an hour of failing for 80 cents.
