PedalPCB VHS/JHS VCR
OD is Glorious
5.00 star(s)
It is sold out here for a reason. Great circuit that makes great boost, chorus and reverb. I have built a VCR before but it is long gone... and I forgot how nice it is. The build is not difficult and the end result is three pedals in one. You get immense satisfaction and very usable tones from this build.
1590bb was sanded and a waterslide decal was applied. Then the pedal was clear coated with 2k satin clear. I used black Taiway DPDT on/on short bats. For the individual LEDs JHS uses, Red, Green, Yellow. I like blue for reverb because it reminds me of water, so the R toggle is blue. All three are bezel-less 3mm diffused (1/8th" holes). I wanted the LEDs to line up with their corresponding labels so I had to use a 9mm off-board potentiometer (see image) for the boost pot. No top jack plate but In did use Switchcraft jacks with special dress nuts. I used a black footswitch with. PPCB brightness breakout board - 5mm red LED in a red freznel for the main bypass LED. The knobs are MXR style in white.
Notice how I had to turn the output jack so that it would not interfere with the off-board boost potentiometer... original had side jacks but I think side jacks would be ridiculous on a 1590bb so they are top jacks.
Notes
  1. SMD FV-1 is required and this one was soldered by PPCB, you can do it, but I suggest you let PPCB do it
  2. 24LC32A EEPROM also must be ordered from PPCB - it is programmed so do not lose it or mix it up
  3. Plan for your three status LEDs layout - my planning was close but no cigar
  4. Plan for the areas where top jacks go... the original uses side jacks and - enclosed jacks will not work as top jacks
You have sold me….. I have been eyeing this board for years, and like you said, it is frequently sold out, or I didn’t want to mess with the SMD.
Your pedal looks great. I love the throw back graphic. It is nice and clean.
One suggestion for anyone wanting to do the SMD themselves: Get some solder paste. This stuff makes SMD soldering a breeze and is clean.
You definitely have to build one. To get an original is over $300 this circuit really packs a lot.
