Caldo71
Hi Folks,
So I've built stompboxes from kits before, but they were the kind like the BYOC kits where all the components are included, and the instructions a bit more step-by-step. This is the first time I've done all that on my own: the Disarray "Reloaded" PCB. Just for the record, when you see all the super-long leads on the photos I post below, just know that it's because I'm not mounting this in a normal stompbox housing—it's going into a 1RU rackmount enclosure.
I THOUGHT I was being a total badass—being super tidy with my soldering, component placement, and polarities, but when I finished it up and plugged in, all it does is go SQUEEEEEEEE!!!
Below, I'm attaching many up-close pics of the entire build, with each photo's file name labeled (top-left-of-board, middle-left-of-board, etc) and some things circled in red and labeled (A, B, C etc) where things MIGHT be funky? But I don't really know...just newb guesses, really. I'll spell out my thoughts on those next, and I'm hoping one of you amazing people might be able to look at my build and see something obvious/standout that I f#$%ed up.
My prime suspects:
A.) Resistor position R17—470Ohms
This one they didn't have in stock at Teyda so I bought one separately at Mouser, where I'm not yet super pro at figuring out how the components differ in size etc. But it's still 1/4 watt, 1% tolerance—shouldn't matter, right?
B.) Resistor position R18—6.81k
This one Teyda didn't have at EXACTLY 6.81k so I bought one that was 6.8k even. Now I'm wondering if that's inconsequential or really super important. So is this bad?
C.) Resistor positions R13 and R16—1M
Same story here as "A" above: Teyda didn't have it, Small Bear did, but the length of the resistor is several mm longer. Again...shouldn't matter as long as it's the same resistance, wattage, and tolerance...right?
D.) Diode position D11—1N34A germanium
Only reason I'm pointing this out is that I forgot to drop in the diode before I put in the big fat electrolytic cap above it, so I made the legs a bit longer and kinda stacked it over the zener below it. Not a big deal, right?
E.) This Thing
This is only used if you choose to solder a DPDT directly to the PCB board...right? I have nothing soldered there.
What do you guys think? Is it one of these things, or do you see anything else? Any help is hugely appreciated....
My prime suspects:
E.) This Thing
