Tayda predrilled enclosures
3 knob type I will fit the Twin Face, they don't currently have a 2 knob, you'd have to use the custom drilling service for the Tone Vendor
Keep in mind the twin face is a 2 knob + 1 switch, and the 3 knob will have holes drilled for pots, not switches. Which just means the hole where the switch is will be a bit wider than it needs to be. It should still work though--you may or may not need to find a larger washer for the switch if it's not covering the hole.
Any ones you think would fit a Terrarium
That would be awesome. Any where you typically get these drilled ?
Tayda Custom Drill Service. Turned out great for me.
Please note those measurements are for a powder coated enclosure and already include the added 0.2mm they ask for this.
SIDE
SIZE
X pos
Y pos
B9.7-15.25.75
B11.70-4.4
B9.715.25.75
A7.2-20.3238.1
A7.2038.1
A7.220.3238.1
A7.2-20.3212.7
A7.2012.7
A7.220.3212.7
A6.55-21-12.7
A6.55-7-12.7
A6.557-12.7
A6.5521-12.7
A4.6 (LED, you might want to adjust depending on what you're using)-15.24-27.3
A12.2-15.24-45
A4.6 (LED, you might want to adjust depending on what you're using)15.24-27.3
A12.215.24-45
SIDE
SIZE
X pos
Y pos
B9.7-15.25.75
B11.70-4.4
B9.715.25.75
A7.2-20.3238.1
A7.2038.1
A7.220.3238.1
A7.2-20.3212.7
A7.2012.7
A7.220.3212.7
A6.55-21-12.7
A6.55-7-12.7
A6.557-12.7
A6.5521-12.7
A12.2-15.24-45
A12.215.24-45
your builds look awesome thanks! also picked up two of these seed boards so i'lll see how these go. i have a back log of 10 pedals to build lol trying to aquire all the parts now
Also note that there's no hole for the micro usb on the seed, I did it at home and filed it (not that well, for that DIY look ;) ), but you could have it done by them.
hi, I'am also planning
SIDE
SIZE
X pos
Y pos
B9.7-15.25.75
B11.70-4.4
B9.715.25.75
A7.2-20.3238.1
A7.2038.1
A7.220.3238.1
A7.2-20.3212.7
A7.2012.7
A7.220.3212.7
A6.55-21-12.7
A6.55-7-12.7
A6.557-12.7
A6.5521-12.7
A12.2-15.24-45
A12.215.24-45
SIDE
SIZE
X pos
Y pos
B9.7-15.25.75
B11.70-4.4
B9.715.25.75
A7.2-20.3238.1
A7.2038.1
A7.220.3238.1
A7.2-20.3212.7
A7.2012.7
A7.220.3212.7
A6.55-21-12.7
A6.55-7-12.7
A6.557-12.7
A6.5521-12.7
A12.2-15.24-45
A12.215.24-45
hi, i want to try Tayda's custom drilling.
would you mind if you tell me what is Tayda 125b's height and length measurement? I didn't had a chance ordering uncoated enclosure from them, that is why I don't have a chance measuring the exact measurement without the coat.
The added 0.2 mm is only for the hole size, as the powder coat adds 2mm of paint (as stated here).
For a bare enclosure you just subtract 0.2 mm to the measurements in the "size" column. The X and Y coordinates would be the same.
what i'am curious about is the dimension (length and height) of the sides.
do you have measurements?
Does anyone know if the Tayda 3 knob type 1 enclosure would fit the Woodpecker tremolo layout? I realize that I would need to drill the LED hole bigger for the switch, and relocate & drill the LED.
