Hi guys, quick question for those of you who know about germanium diodes, leakage, etc, I have an old modded tubescreamer clone I bought maybe 15 years ago when the boutique craze first got going, it’s been sat in the closet for years and I pulled it out recently. I was poking around inside to see what was going on and noticed that some of the diodes may be backwards, just wondering how that would work (or not work!).
It has a 1n4001 + GE diode in one direction, and a 1n4001 + GE + LED in the other direction. The germaniums look to be Russian ones (green stripe) and I believe (all?) Russian germaniums have the stripe on the anode. As you can hopefully see in the pic, that would mean the GE diodes are in backwards.
Normally I think this would just nullify the clipping diodes, as if they weren’t there, however I understand that the old Russian germaniums tend to be quite leaky. I have a few D9E diodes on hand and I measured a few, mostly in the 70k to 300k range when measuring reversed resistance.
Does this mean that the clipping section here is essentially “SI diode -> large resistor”?
The pedal is loud, louder than my other tubescreamers, but doesn’t sound like no clipping diodes. Also, the LED does light up when I play, so it’s certainly doing something.
It’s built on a BYOC board dated 2006. This is the bodenhamer ‘bloody murder’ overdrive, if anyone wants to know.
Are there any germanium diodes that look like this with the green stripe that would have the stripe on the cathode?
Thanks guys
Thanks guys
