Idlebeach
Howdy partners. I am not a circuitry genius like it seems like a lot of people online are. Perhaps I am not skilled enough to finish this but I think with a few nudges this can be figured out. I have built quite a few pedals and troubleshot a bunch on my own but I am just not sure what to do here.
Here's where I am at. When the effect is engaged signal goes through and is -sort of- effected. I can get a sort of envelope filter Q Tron type sound from it. If I adjust the BBD trimmer I can get it to a point where it is distorted and then back off a bit. Sometimes it has a very subtle phasing type sound .but after I move the knobs around it seems to disappear? Most of the pots don't seem like they do anything aside from the gate(?) potand volume. The dip switches work, definitely notice a boost so that's good.
I subbed out a 2sk30 for the 2sk208 initially but later saw some people had luck with j201 - seems the same? I couldn't find bat48s so I think I used bat46's.. I used a surface mount version of the LM258P but I think I fried that but I have another one. I am curious if there are any common ICs I can swap the LM258P for - I have a decent variety of common ones. Not sure what it's doing in the circuit so I don't know how important it is to get the exact right one. I am also using a Panasonic MN3207 instead of the new cool audio one. Not sure how to spot if it's fake or not but I built a chorus with the same ones and it sounds great so I assumed it would at least function. Even swapped it out with a different one to make sure that wasn't the big issue. If it could be the major issue - anyone got one of the new MN3207's in a parts drawer they can sell to a pedal pal?
Other than that I accidentally got a B1M dual gang but I am sure that will only effect the taper and I plan to replace it eventually - if I can get it working.
I apologize this was kind of a longer post and I can't offer up a ton of info to get started. I don't know if audio probing would help here - I have only been able to navigate it myself on much smaller simpler circuits so I don't know where to go on this big daddy. I have a DMM at the ready if anyone needs readings - just tell me where to go and what to do and I will do it!
Thanks so much. I hope someone out here can help me troubleshoot this. I feel like its got to be something really simple at this point.
just incase the photos are small you can view them on imgr
