andare
This was a tight build, I also soldered two of the trimpots in the wrong spot because they fit better before realizing they were different values. All fixed even though TR1 looks upside down but there's only one way it goes in and it works as intended.
Once again this was a kit from Musikding. I replaced the 33uF electros with 5mm ones for a better fit (and still they're all crooked). I also used those nice blue ceramic discs instead of the tiny brick-colored ones they supplied.
Musikding always messes up the jack holes and the Lumbergs never fit right, hence the electrical tape.
I use kits cause I can't drill enclosures but I'll see if I can remedy that. After building 8 pedals I'm not always happy with the parts provided, might as well order my own.
This is a good pedal, easy to dial in with the trimmers. Plenty of volume and the Low and High knobs can fatten up or slim down your tone.
I wish it was chewier and there more speed and depth on tap. Also a bit noisy but nothing major.
Looking at the Electrovibe next!
