Im hoping to be able to make it all fit exactly the same as the original pedal. I got the extra pcb for the foot switch which i initially forgot to order and luckily for me, Pedalpcb hooked me up before my order was shipped after i reached out themLooks good so far, watch your switch placement! On the PPCB board, the switch is in line with the bottom knobs..
Much Appreciated!!If you've got ANY questions while building your first one don't hesitate to reach out. We're here to help, not hold you down!
I believe what Sturgad was referring to is the placement of the toggle switch.Im hoping to be able to make it all fit exactly the same as the original pedal.
O ok, you mean the Board doesn't fit into the enclosure the way that the holes are pre drilled? This is the type of enclosure I baught. The way i was looking at the pcb it seemed like it would fit but if not ill do like you said and make some ajustments to make it workI believe what Sturgad was referring to is the placement of the toggle switch.
It's doable but you'll have to float the PCB slightly higher in the enclosure to put the switch where you want it The easiest (and most secure) way would probably be with long pin 16mm pots then just run wires to the toggle switch.
Lol I could totally Amp the graphic content to be a little more explicit but i believe the pedal is already controversial as it is. However id be totally willing to help someone achieve a more worthy graphic to go with the name if they wanted to build one I'm great with photoshop just not so much illustrator yet lol.Those graphics are way too tame for a pedal with that name.
