Is there a way to open SpinASM IDE files (.spn) in SpinCAD? I know this is a pretty 101 question but documentation for SpinCAD seems to be sparse
Where’d you source your CH341A from? Did it end up being legit? Given how many super cheap 341A programmer sticks there are, I doubt they’re counterfeited much, but you never know.Pardon the flux. I forgot to scrub it down.
I'm curious where @fig got his from, but I got mine from an aliexpress seller (YT Electronics) that had the most orders of a 341 on aliexpress. A few reviews sounded like they tested them and worked. I usually have better results with SMD stuff than DIP so I wasn't too worried about soldering it to my board but I'll let you know once I actually get it wired up to try it.Where’d you source your CH341A from?
Apologies for the delay, I was battling a nasty stomach bug through the weekend.Does the CH341 need any setup on Windows or should theoretically AsProgrammer be able to see the eeprom just with the fv1 dev board connected over usb? USB plugged into my dev board, tried with and without dc plugged in
edit: definitely a driver issue - windows says it can't find a driver for it in device manager, and googling some of the identifying stuff from the device details tab does bring up ch341 driver info. installed some from wch but still can't get it to read
I run it in a VM Windows 10 & a frugal Aspire all-in-one. I don't recall having to download additional drivers but you do have to select the correct EEPROM from the menu. I'll double-check this evening and get back to you sir.
IC->PedalPCB->FV1->_24LC32A)Yup, and you have the CH341 selected in the menu. Are you running a VM? On the PC, when attached it appears as a UART LPT , so pretty generic.
Superior Google-Fu!
I've gotten better over the years, but new OS features usually make things worse.
