r.nandez54
Am I the only one getting a ton amount of hiss from the full size Parentheses when the octave is activated? Is there a way to fix this?
I’m really pleased with the distortion + boost. Low noise floor and powerful sound. When I switch on the octave though, the noise is significant.I've never used this pedal, but I'm curious what they did to the Rat portion to make it quiet, even with a boost. The Rat is one of the few circuits that I find absolutely unusable due to its noise floor (also looking at you HM-2)
What diodes did you use in D1 D2? It’s been a while since I gave mine away but I don’t remember having this issue I matched a pair of schottky 5817’s ,you probably have enough on hand to swap them out with relative ease and see if that helps. Bat series diodes might be worth a shot as well.Sorry to bump a really old thread, but I have the same issue
Loud wind noise when octave is turned up.
When just using rat and boost no noise at all
Any ideas?
