pcb rookie
1- Led does not light up. I've tested with a 2032 battery before installing to make certain it functioned and to identify A&K. I tested it again, once soldered in place, with the same 2032 battery while and it does light up. I tried reversing it just in case I had everything wrong ... still did not work so I replaced with another working led and did all the testing/polarity check before and after installing ... same issue.
2- I get bypass tone out of the pedal but no sound comes out when engaged. I check soldering for possible bridges. I have triple check the wiring. I've checked and there is power going to the PCB. I tested all components before soldering them in place.
I would be thankful for any help, tips or potential test to help work through the issues ...
here are some pictures, they are not the nicest pictures. Don't hesitate to ask for specific additional pictures if that can be of any help ...
