Kliche Ge Diodes which ones do you go with?
steviejr92
Authorized Vendor
So I just bought a kliche pcb this will be first Klon build and I got a bunch of different ge diodes I have 1n34A, 1n270,1n60, d9d,d18,and D9E. Was just wondering who’s put in different ge and which ones sound the best to you guys. Would like to hear anyones opinion.
So I think there’s a misunderstanding here I meant frying the diodes by soldering them in 🤣
Mind that your "D" series Ge Diodes may be reverse orientation from your others. In other words, the banding may be on the anode side and not the cathode side. I found out the hard way:)
Orientation of the diodes won't make any difference in the Kliche but it's worth knowing for any other builds you may use them in. Quick check with a multimeter will confirm.
Thanks for the tip will keep in mind when it comes time to build!
I went with some D9E's. They result in a tad softer clipping which, to me, sounds a bit better. Along with that, I use a 6n8 instead of a 3n9 for C15. The combination of these two little mods results in a slightly softer, less treble-y tone. Not quite as bright as a stock Klon basically. I personally like it. It's a relatively subtle change though.
I might look at this I want to build something a little different than a normal Klon I’m def going to give the D9E’s a try!
The C15 mod is a common mod. I did that with all my Klon builds as well. You can go up to 8N2 for a pronounced effect, but like @jeffwhitfield I've used 6N8 for all the Klon's I've built. It makes the treble much more useful. Otherwise, it kinda goes from "bright" to "brighter:)
Lower forward voltage will cause the clipping to happen sooner, that is you may notice more compression and distortion kicking in at lower gain.
Actually, from my EXTENSIVE SCIENTIFIC EXPERIMENTS...... :p ........I've noticed in my last Klon build that the Ge Diodes don't have as much affect as all the hubbub around them would indicate. I was building a Klon for my brother and I had the bright idea of putting some different diodes options on a toggle switch for him. I tried a bunch of different silicon and Ge diodes and differences were so negligible that it was hardly worth doing. I think the whole magic Ge diodes things in Klon's are just more of the Centaur mythology BS. I actually have Bat 41's in my own Klon.
