The Gator
Finally finished my spacialist build. Pretty awesome fun reverb! Lots of settings. I knew I was going to have a hard time remembering what was what, so I made a graphic of the parameters and put it on the end. It is a clear water slide decal
That is ethnocentric font cut out of siser glitter Azurite vinyl on top and it is all protected with acrylate lacquer clear coat.
I found matching knobs at small bear. Meaning they have the same style in both 6.35mm round shaft set screw type, and 6mm 18T push on type for the rotary selector switch.
Great fun building this circuit and it sounds awesome!
