Passinwind Open Source Hybrid Filter Preamp Builds
Cool, the new one uses those same boards too. So you can add either or both other modules if and when you feel like it. I already have HPFs built into all my bass amps anyway and don’t necessarily need the variable gain stage, but those features are very important to two actual paying customers, hence the bigger enclosure. Plus, I really don’t like to do the exact same thing twice! :cool:
I like modularity, especially in this case.
New v2 125B board in the works, the first real open source contribution to my project that I didn't have to do myself:
This one uses all Tayda parts and there are no SMDs. The designer has already ordered a set of boards from JLCPCB, so hopefully it will go live within the next month or so. And then I'm going to hand off a schematic or two to Robert and let him take things wherever he feels like, because why not?
Latest version of the Baxandall based Bass/Mids EQ module:
And the latest resonant filter module now has gain leveling and polarity swapping built in, so the overall build will finally be non-inverting. Gain range is tunable, my first testers are set up for -10 to +6dB with unity gain at noon.
Family photo of my four WTHPF builds, the one on the right is the Peacock Ore finish and for that build I optimized a few more aspects for upright bass:
The new gain leveler circuit configuration seems to be working really well, so I can can probably go back to something smaller than the 1590BBS now if I build any more of these.
What, no gut shot? 🧐
Ignore the junk behind the curtain...
Too scary, and mostly all you could see would be the little Nomex origami boxes I wrap the modules in before I stuff everything into that enclosure. Starting the next build today or tomorrow, the last of this series. Then I'll get to work on some much tidier solutions with all three of the current modules on one board, way less offboard wiring, etc. But the modular approach I've been using has been super useful during the R&D phase.
Here's a project contributor's new build, using a fiberglass fascia plate made by JLCPCB:
Everything sourced from JLC or Tayda, and he did his own board layout which he has kindly shared. Just waiting on his final testing before we take it live. This is his second go-round, same guy I mentioned a little upthread.
And then I'm about to truck on down to the post office to pick up a couple of these new enclosures that Amplifyfun just did for me:
Having Spencer drill all the holes is so so worth it! This version is always-on, has side jacks, and is meant for desktop usage rather than being a floor pedal.
My version of the first one in post #30:
Tayda drill and print job, which took a bit longer than usual but came out fine. This particular build especially shines on acoustic guitar, with either piezo and magnetic pickups.
Most recent WTHPF (v4) builds:
v2 needs one more board revision, so live launch is probably about 3-4 weeks out.
If you were to go for a fixed resonance, how much boost would you aim for?
I want to try this out on fretless and have a switch for flat or peaked resonance. I'm thinking a +6db resonance boost would be good but im not familiar with this style of preamp.
3db seems like it would be too subtle and more than 6db would be too much.
Thoughts?
Thoughts?
6dB is an excellent place to start for fretless, IME. I recently did a dedicated resonant LPF just for the bridge pickup on my Marco Bass:
The neck gets a Baxandall Bass/Mids EQ board and then there's active mixing with two detented volume pots with unity gain at the detent and individual boost/cut available per pickup. Stereo output is available but not currently implemented. The Q switch is set up for +5 and +9dB right now, I may eventually swap in a three throw switch to allow a cut only setting as well. +3dB actually can sound a lot like a passive tone control, although it cuts at 12dB/oct at everything above the resonant peak, so a steeper slope than a typical passive control.
The mix section, non-inverting LPF, and external buffer board for the LPF will all go on open share too, as there are finally some lower current opamps readily available that I really like.
I spent my spring break finally working on a preamp for my fretless based on Charlie's preamp.
Bass ~ +- 12db @ 70hz
Mids ~ +- 12db @ 600hz
Treble is the lpf module with a +3dB/+6dB resonance switch
All the EQ curves sounded great in my daw so I'm excited to hear how it sounds. I'm not totally convinced that Ill like the LPF treble control but the only way to know is to try it in person.
PM me, I have a few trick new parts that might make your build a little easier.
If you get it right you may never even think of going back to a shelving control, IMNSHO, but it's very very easy to not get it right! Just another tool in the box, hard to say from here if it's the right tool for your job. ;)
