Well…. I guess I confirmed that guitarpcb has zero customer service… Wrote them an email just asking if they assume that failure rate was normal occurrence and crickets…. Never replied… At least I know what to expect and I won’t be ordering from them again.
That's exactly what I did with my first go-around with that DCA75 measurement result. Then I got curious and tested them anyway.Hmmmm…. maybe I spoke too soon? I guess I better throw them in one of my chop shop builds and give them a bias to see if they indeed are fine… I set them aside and labelled them just in case the tool was reading then weird. Thank you for the heads up and I may learn something from it…going to test them in a build later tonight to see.
haa... I have about 30 different builds in progress... You mean what are you going to actually finish... I have a couple chop shops I can use to test the jfets because they have sockets already there.That's exactly what I did with my first go-around with that DCA75 measurement result. Then I got curious and tested them anyway.
Looking forward to your results. Whatcha building?
In my experience with buying hundreds of J201s from GuitarPCB, not one has been bad. I eventually hand tested every one of them with my DCA75. And those that read as 2 diode junctions actually worked when applied in a working circuit.Oh no… should I invest in a DCA75 or DCA55?
I have a ton of J201s from him as well.
Ok I’ll plan to get one. Are they quite a bit more expensive than the DCA55?In my experience with buying hundreds of J201s from GuitarPCB, not one has been bad. I eventually hand tested every one of them with my DCA75. And those that red as 2 diode junctions actually worked when applied in a working circuit.
But for the sake of having an excellent piece of test gear, I highly recommend the DCA75 over the DCA55 because it shows more data about the tested device than the DCA55. The DCA75 also comes with Windows software for obtaining trace curves on BJTs, FETs, diodes, LEDs and other devices. (see attached image for some traces ran on two different JFETs)
View attachment 57894 View attachment 57895
Amazon has them for about $186 . . .Ok I’ll plan to get one. Are they quite a bit more expensive than the DCA55?
Digikey says they have some supply issues on the DCA75.
