Skeptical buffer high pitch sound
servusjon
I build the Skeptical Buffer and love what it does. Strangely, when using with my Delay (LVX) enabled in series mode (half time speed) it generates a high pitched sound. This sound happens when Skeptical buffer is bypassed (a lot quieter) and louder when engaged. When I remove the pedal from the signal path the high pitched sound is gone. Any idea what could happen? Strangely it also happens when bypassed. not sure whats happening
how do I know if a pedal has a charge pump? I have the hudson broadcast, KOT, Boss sd1.
Also I power everything individually with OJAIs
Charge pump is an IC, like the TC1044SCPA, 7660SCPA. It’s the IC on the bottom (IC100), not the TL072 dual opamp. If you’ve got an extra TC1044 and you socketed the IC, I’d try swapping that.
