guitarbruno76
Hi to all,
I' ve got the Muzzle noise gate from Musikding, a good one.
For some reason, I'd prefer to avoid the FX loop of my amp , cause adding too much jack cables in the circuit...
So I'd like to choose Fortin Zuul+ method, 4 cables with no FX loop.
When I experiment it, it doesnt work fine, I have sound, but the noise gate is too drastic! It cuts the buzzes when I use disto, but the sound is hesitant. Also when I use clean sound, the sustain is bad.
So I can only use the Muzzle, with simple option ( no side chain) or 4 cables option with FX loop of my amp.
The pedal chain with problem is:
Guitar _ Side chain in - Side chain out - All noisy pédals (wah, comp,od, dist) - Noise gate in - Noise gate out - All space and mod pedals ( chorus, reverb, delay...) - Amp.
So do you encounter same problem?
Thx to all, greetings from France.
Bruno
Bruno
