First Build - El Sol not working
cyrano456
I'm getting no signal from my circuit, just noise when it's on. I've troubleshot it to the best of my ability, every trace I can find gets a beep when I test for continuity. From the other thread with a similar issue, it seems like my LM386s could be the problem, but I'm not sure how to check them. Hoping that's not the case since I didn't have the foresight to use sockets. 1000002338.jpg PXL_20240802_195141574.jpg PXL_20240802_195159068.jpg PXL_20240802_195613922.jpg
your wiring and soldering needs a bit of work... Are you aware that the boards are designed so you dont have to offboard wire the pots? Your led wiring looks it needs work as well... you should just tie the hot and negative lead into the led pads at top of the board.. Also its a good idea to use sockets for the ic chips as well...Your input/output jacks could also stand to be the metal type instead of insulated to help with getting ground.
