I'm joining the PCB party. I fired up my prototype last night, it works great (except that I wired three of the pots backwards). It sounds awesome though!
For low gain silicon Q2/Q3, I used these
2n4123 parts from Tayda. Cheap and plenty of stock. The one I happened to measure on my CCT said HFE of 94.
What is the reason for using low-gain transistors in the Q2/Q3 positions? What would happen if high(er)-gain transistors (e.g. 2N5088, BC549, 2N3904) were used?
Also, encouraged by how this sounds, I'm flirting with the idea of picking up the Major Overdrive for an "inspection". I would expect the circuit topology to be the same as the Diamond Peak/Hybrid Overdrive, but with different component values.
Has anyone experimented with other JFETs for the Q1 position? Earlier in this thread, it was suggested that J113 with Vp < 2V should work. Just curious if anyone's actually tried any alternatives. (I used MMBF4393, works great; but I have a fair amount of random TO-92 JFETs.)
