What is this transistor doing here?
Fet_street
Can anybody tell me what this transistor is doing here? Yes I know it has an element of voltage divider but I wanna be sure I don't break the amplifier. The d600e transistor failed and I want to know if there's any way I could bypass this transistor to get it running today or any common transistor I may have laying around to replace it with Screenshot_2024-11-30-08-29-24-263.jpg
It's an NPN power transistor so if you've any spares with the same voltage rating as the 2SD600E it should be fine I'd check anything you've got against its datasheet or just get one I think you can still get them easily enough
