Acrobat parametric distortion 2P6T rotary sourcing
Question. Does the Acrobat use all six positions on the rotary or just five like PDF-2? And, setting ring setup and location/indexing of the 3mm post? Thanks,
No. It uses 5 settings. When you get the rotary, you will see that you use a washer to set the setting on the rotary. It is straightforward.
