Minnow Voltages wacky?- need a second set of eyes
DGWVI
Pretty sure I've got a wrong resistor or two somewhere, but haven't tracked it down.
Only sub is a 220r in R20.
I get audio through, including LFO thumps, but is a heavily low passed signal, and definitely not working correctly
IC1
  1. 0.03
  2. 0
  3. 0
  4. -9
  5. 0
  6. 0
  7. 0
  8. 9.2
IC2
  1. 0.04
  2. 0
  3. 0
  4. -9.01
  5. -4.49
  6. -1.05
  7. -6.6
  8. 9.2
IC3
  1. -7.58
  2. -0.12
  3. 0
  4. 0
  5. 0.2
  6. -8.6
  7. 0
  8. -1.18
  9. 0
  10. 0
  11. 8.7
  12. 0
  13. 0
  14. 0
  15. 0
  16. -7.5
Q1
  • D- 8.71
  • S- 0.01
  • G- 0.2
Q2
  • E- 0
  • B- 0
  • C- -7.55
Q3
  • E- 0.02
  • B- 0.2
  • C- -6.14
Q4
  • D- 1.4
  • S- 9.01
  • G- 0.02
Q5
  • D- 9.2
  • S- 0.2
  • G- 0.04
IC100
  1. 9.2
  2. 5.3
  3. 0
  4. -3.73
  5. -9
  6. 4.3
  7. 5.8
  8. 9.2
  9. 1000030190.jpg 1000030173.jpg 1000030170.jpg 1000030172.jpg 1000030171.jpg
I've got the toggle replaced with a footswitch, verified continuity there, and it checks out.
I'll have to wait til tomorrow to run full continuity check or audio probe, but hoping someone catches something I didn't
Resistors Nope.
As you noted only sub was 220Ω for R20.
All other resistors check out, visually.
Perhaps you inadvertently swapped the trimmers?
The 1458 below the B5k looks a little wonky, maybe try reseating that one.
Or...
Resistors Nope.
Or...
Trimmers check out, though those wouldn't effect the envelope mode. All chips have been swapped and reseated.
Replaced / tested all caps except those in the power section
Also desoldered one leg of every resistor, and one was out of spec, but replacing it didn't change anything
I need to run another continuity check when Im not in a rush, but nothing seemed off
I get audio up to pins 3 and 12 of IC3, but no envelope action anywhere. Jumping those pins does nothing
Similar threads
