DGWVI
Hopefully the pics are clear enough
Having an issue with the power delivery on the B side of this latest Duo-Phase- the LFO will not start, but the phase stages work otherwise.
I've gone over everything several times, and have replaced everything in the LFO section and power sections for Side B and kinda stuck on what to do next. The Depth and Trimpots all effect the LEDs as they're expected to, but I get no movement from the LFO
Removed the Feedback pot to make photos easier.
Voltages for the borked side... As you can see I'm getting static negative voltages on both ICs 5B and 6B, even after resoldering, cleaning, replacing (everything, including the switches but, except the sockets), and cleaning again
I also get continuity between IC6B and all three pins of the LFO switchz regardless of which position it's in.
Voltages for the working side
I've gone over everything with a flashlight and magnifier, and see no solder bridges or damaged traces.
Side A works perfectly
 ) and that all checks out according the the schematic.
