Cepheid chorus no efect and no leds
mike_666
Hi all, it's been many years since I had go at making a pedal, so thought I'd have a go at the cephoid chorus.
I fear I maybe being blindingly stupid here (trust me it happens a lot to me!), but I get the dry signal, but don't get any effect and the leds don't light up either, but they do work.
Any help would be most appreciated
So today, I discovered I'd put the leds in the wrong way round! I know have the lfo working correctly, and I remade the dodgy soldering on the break out board.
I still don't have any effect, even after twiddling the trim pot. What I'm thinking is it's not getting power, as the led doesn't light (it works I double checked that), and when the switch is turned on I get no effect just sort of noise which does get louder if I use the trim pot.
You should start your own troubleshooting thread. Provide clear pictures of your board and all wiring connections.
Hi sorry for the delay, it's been a bloody awful week at work.
Yes it's the mn3207 chip I'm using, I'll away and check the voltages and the jumper pad and get back to you kind folks.
