I was not sure how I would mount the board at first and those were kind of tall. They fit well around the pots.Hey, neat build!
Your electro caps soldered to the rear, just an aesthetic choice? It looks super tidy.
Sadly I'm of no help here, I never tried the mercurial.Nice, clean build! Can you compare this to a Mercurial Boost? Better? Worse? Same?
Yep, they are under because of space managementLooks classy! Are the electros on the underside?
Never thought about that, but I get what you are saying.Reminds me of @Passinwind preamp.
I wasn't familiar with the NE-1, so I just did a bit of research to confirm my guess. Short answer—no, they do different things (although the Mercurial might be able to closely imitate what the NE-1 does. Mercurial is a boost, with a tunable notch filter. You pick a center frequency, and then you can boost it, or reduce it, and then it gets blended with the original signal and both get output through a gain stage that can also allow it to be a boost. (One of my most favorite sounding IC based boosts.)Nice, clean build! Can you compare this to a Mercurial Boost? Better? Worse? Same?
I will have to play with it a little more. I really think level work intuitively, so CW for higher output, it's just that unity is really high, I'll really have to confirm the interaction between the knobs and switch.I'm guessing the higher you turn the level the lower the output gets—does that track with your experience, @Nic?
I actually have a different EQ pedal in design that combines a one band PEQ and a variable HPF, using a 9V—> +/- 15V Traco power converter chip. It has plenty of headroom to drive any power amp directly and my primary projected use case is FRFR powered speakers. I hope to add it to my open source GitHub repository sooner than later.Reminds me of @Passinwind preamp.
You had a design where the resonant LPF was used like a tone control yeah. Kind of an alembic deal?I actually have a different EQ pedal in design that combines a one band PEQ and a variable HPF, using a 9V—> +/- 15V Traco power converter chip. It has plenty of headroom to drive any power amp directly and my primary projected use case is FRFR powered speakers. I hope to add it to my open source GitHub repository sooner than later.
Yeah, that’s the current open source one.You had a design where the resonant LPF was used like a tone control yeah. Kind of an alembic deal?
That's what I was thinking of when I brought it up.
