1044scpa vs 7662CP vs 7660
Oh just because I’m dealing with a build that is “whining” and this was one of the more helpful threads on charge pumps here. I noticed the 7662 was mentioned but only briefly and wanted to contribute.
LTC3863
Higher current output and high voltage input and up to 350kHz
If you want to max spec it...
I hadn’t heard of this one, I’m checking it out now, thanks for the suggestion! 😎👍🏼
While I hope it works out for you, what we sacrifice for maximum voltage is oscillator frequency. Personally, I find the latter more appealing.
From the TC7662 datasheet:
I mean, if VFE circuits aren't having squeal/heterodyne problems, that's something, but butter safe. I've just defaulted personally to the TC7660H, which has a frequency of 120kHz, but a max input voltage of 10V. Lower than the TC7660SCPA's 12V, but no pin bridging required, and nearly 3x the max frequency.
I totally agree with the frequency being the most important factor with a 9+/9- CP.
For preamp designs, when it comes to higher voltage split rails without whine I’ve defaulted to the big DC>DC converters in SIP packages like the TRACO, MEANWELL RECOM ones.
However for just wanting some headroom and to design in the dual rail bi-polar way for basic pedals, knowing about better CP chips is great! I will absolutely look at the 7660H!
Hello, if you got charge pump whine I suggest to put some 470nF MLCC caps at the input and the output(s) of the charge pump to ground. Works every time for me. Have a look at the aion Straylight and Ember. That's where I first saw people doing it.
No one mentioned the LT1054? Seems to solve all these problems. Automatically switches at 25khz. Drop in replacement for the 1044 which is good for designs that already use that.
Can't speak to every person or instance, but looking on the surface, could be price per part? In thru-hole, a 7660S/H is $1.27-$1.40, where a 1054 is $4 on mouser currently.
I guess I don't mind spending the extra on parts where it really counts. I'm certainly not out here buying WIMA film caps or Nichi Gold electrolytics or anything like that. But if you're having problems with noise and wine, which really affects the experience of using the pedal, why not just invest in a quality part?
Banzai Music has TC1044SEPA, Musikding has TC1044S. I'm not sure if those are the same, maybe I should ask to Musikding. :)
Will I have any problem with one of those tow?
I would like to have this chip for the Triangulum Boost, Fortin 33 clone.
SCPA, boosts to 45k
On mobile and don't have the datasets in front of me, but iirc the difference between the SEPA and SCPA is temperature tolerance maximum on the SEPA is wider in both directions. I got samples from Maxim back in 2012(?) and have used both in klones.
But as long as there's an "S" after the "1044" they will boost. But definitely check the datasheet.
But in practice, yeah, keeping it all out of any audio range is preferable.
LT1054 is still a charge pump and has ripple. I can get my Electrovibe to whine.
Have you tried adding a small capacitor (between 5pF and 20pF) between pins 2 and 7? According to the data sheet, that will increase the oscillator frequency.
On a side note, the price for these things has really jumped. I bought a bunch of them in March 2023 for $1.85 each. It's not even three years later, and they're now $4 each. I can see why people want an alternative.
You can usually get them for around a buck a piece if you don't mind SMD.
The TP7660H is there for $0.30 but it only runs at 10kHz, unless you add an external clock.
I paid NZ$4.90 ea for a lot of 10 LT1054CP in July, already they are NZ$5.48 for 10. This must be tariffs right? One of the reasons I have switched to LCSC recently.
Hi fellow kiwi! I've also switched from Mouser/Digikey to LCSC due to price increases. I went for the Microchip TC7660S due to the 45kHz boost frequency, got an order coming in ~December so we'll see how well that performs.
Sorry, didn't see this message until now. Honestly never tried. According to datasheet you can bring it up to 35k. That's the same as 7660S with pins 1 and 8 shorted. And you can get these to whine, too.
We won't hear the 25k nor the 35k. What we hear is heterodyning, when two of these overlap and the result is a lower freq. So the best thing to do is shield the rest of the circuit from the ripple.
