...And Now for Something Completely Different: The Autonomous Collective of Tone [King of Tone]
Bricksnbeatles
Member known well
Here's another one that's long overdue. I first came up with the idea for this one back in 2020. Ordered the board from Fuzzdog in 2022, and ordered the enclosure in April 2023.
Let's get the technical stuff out of the way first:
The enclosure is a 1590BB in 'Metallic Gold' from Tayda. It's built on a Fuzzdog Emperor PCB.
The circuit is built more or less stock, with some caveats that I'll note below
  • High-Gain red channel. This is just replacing the resistor in series with the gain pot with a 100kΩ (R5 on the Fuzzdog schematic)
  • Standard/Low-Gain yellow channel. On the fuzzdog schematic the standard/low-gain resistor (R5 for red channel, R16 for yellow channel) value is listed as 10kΩ, but I used 1kΩ which is most commonly found as the standard value in real KOTs.
  • Input cap (C1 for red channel, C10 for yellow channel) for each channel was bumped up to 22nF from the stock 10nF. 10nF is the value used in both the Fuzzdog and Aion schematics for the King of Tone, but the PedalPCB Paragon suggests 22nF. It seems both values have been used over the years, but since I'm mainly using an AC30, I figured the extra little bit of low end would be welcome.
  • Fuzzdog Opto-Puss optical bypass. I had ordered TLP240D optocouplers from Mouser for this last year to replace the now-obsolete TLP222G that the bypass calls for, but as I was getting ready to populate them (the very last components I was populating no less) I realized that Mouser had sent me the SMD version, so instead I soldered in some DIP4 sockets, and socketed some very suspicious supposed TLP222Gs that I got from aliexpress a year or two ago. They seem to work fine, but I wanted to socket just in case.
  • Presence controls for each channel are wired as external controls. This is conveniently already integrated into the design of the Emperor PCB.
  • The dip switches are replaced with a pair of external DPDT on-off-on toggle switches. each switch controls one channel, with up being the hard-clippers active (Distortion), down being the soft-clippers active (OD), and the middle being no-clipping (Boost).
  • Speaking of the clippers.... 1S1588 diodes for the hard-clippers, courtesy of @MichaelW, and BAS33 diodes for the soft-clippers
  • External toggles added to bypass/activate the internal charge pump for each side. This is integrated into the design of the Emperor PCB, but that's designed to use internal slide switches for each of those, instead of an external toggle.
  • 1044SCPA chip instead of a 7660S for the charge pump. no other reason than it's what I had on hand.
  • LEDs are scuffed up with a scotchbrite pad to diffuse them a bit and make them a bit nicer looking when lit up.
As far as the build process goes, there were a few slight hiccups. The jacks are moved over from where they're intended to be by the board layout–– this was to accommodate the external voltage switches, however the new location puts the jacks uncomfortably close to the input and output jack connections on the PCB. In order to keep the tip of the jacks from grounding out on the solder nubs from the input and output ground connections, I instead grounded the input and output jacks via the 2.1mm DC jack's ground connection. In the future, I would opt to use a 1590BBS/1590BB2 enclosure to give the jacks a little more room to breathe. The sockets for the optocouplers also add just enough height that the lid can just barely close– if it wasn't for me having the wrong optocouplers on hand, they wouldn't have been socketed anyway, so it's really just a matter of circumstances. It's able to close just fine anyway, but I really had to make sure the footswitches were as deep into the enclosure as possible in order to make it not be a problem.
It's almost 2AM now, and I'm ready to crash, so I'll come back to this at a later point to give some more insights into this build, the background of the name, and my love of Monty Python.
Autonomous Collective of Tone (3 of 5).jpg Autonomous Collective of Tone (5 of 5).jpg Autonomous Collective of Tone (1 of 5).jpg Autonomous Collective of Tone (2 of 5).jpg
Lovely build. Looks like you really took the time to get this one right. Neat trick with the scuffed LEDs for diffusion, and big love for the Monty Python quote.
Looks great!
Have you by chance measured the current draw with either and both channels on? I’m curious how much current the optical bypass requires.
Nice work!!! Love the MP quote, too, from one of my most favorite sketches!
Strange women lying in ponds distributing swords is no basis for a system of government. Supreme executive power derives from a mandate from the masses, not from some farcical aquatic ceremony. ... I mean, if I went around saying I was an emperor just because some moistened bint had lobbed a scimitar at me, they'd put me away!
Hi Nick, I'm just looking at this again as I'm about to build one using the same PCB and yours is just so beautiful! I've been sourcing the few parts that I didn't have, mostly diodes and the optocoupler. Your photos are going to be really helpful when it comes to the layout in the box.
I was wondering if you be willing to share your file for UV printing - just so that I could check how it needs to be formatted? This would be my first UV print and it's a Christmas present for my daughter. Totally understand if you'd rather not but thought I'd ask!
Have been on the wait list so long that in the meantime I've learnt to make pedals ;) Was meant to be my turn earlier this year but I think I'll just make my own!
Was also wondering where you got the LED bezel, very cool!
Cheers
Dave
Cheers
Dave
Hi Dave!
Thanks for the kind words!
Unfortunately I can’t share the UV print file— aside from being something I’m generally not super comfortable sharing, I sadly was dumb enough to save all of my UV print files from around the time I did this one on my university email’s cloud storage space, and since I graduated back in May, I lost my email access a few months ago. Doh!
If you need some help with the formatting of the file though, definitely post in the “what’s on the drawing board” thread! Lots of people here who can help make sure your daughter’s gift looks awesome!
Now, as for those bezels… funny you should ask. I actually have no idea where I got them, and I’ve been looking for more for ages. They’re the only cup-style 3mm bezels I like— the ones from tayda and small bear both are kinda crummy imo. These were my very last pair, and I’m desperate to find more because I have a handful of other builds I wanted to use them on.
